p2293 2008 cayenne v6
P2293 Fuel - high pressure
Possible fault causes:
- Predelivery quantity or pressure in fuel low pressure circuit too low
- Pressure relief valve in high pressure circuit faulty
- Fuel high pressure sensor faulty
- Quantity control valve faulty (in fuel high pressure pump)
- Fuel high pressure pump faulty
- High pressure injector(s) (fuel injector(s)) faulty
  • Like 1
  • 3 years later...
Same 2008 Cayenne V6. Had diaphragm replaced. Car running poorly with P2293. Since this is immediately after the work being done, any likely thing to check in the mech's poor assembly? Relay, connector, blown fuse, leak, etc?
55 minutes ago, pchak said:
notify
If you are attempting to "bump" your earlier post, that is prohibited by the forum rules you agreed to when you joined.  Future "bump" post will be deleted........
