Hi All,
I've had a recurring problem with a CEL that is caused by a P0118 code.
According to the Porsche dealer tech line the problem may be at the control valve for the transmission oil cooler.
Upon further inspection myself I found that the vacuum lines to the valve and control solenoid were missing completely (left off at factory).
I need for someone out there to have a look on their own GT3 just forward of the trans cooler to see if they have vacuum lines attached and if so where is the source.
It makes no sense to me that Porsche would install a valve and control solenoid and then not connect it. I think this was an oversight at the factory.
Many thanks.
Ron :help:
Thanks for the page from the PET I have that already. There are no hoses at all on my car. :(
Have a look at this:
gt3_trans_cooler.pdf
BTW... my OBD II manuals says that P0118 is "Short circuit to B+". Most likely causes are: Wiring, Temperature sensor, or DME control module.
Ron, check my Rennlist post. It looks like my car does have all of the hosing and vacuum lines that I would expect to see.
