My rear defroster light stays on. It will not turn off. I have replaced the relay, the switch and nothing seems to have fixed it. Any other areas I could look at?
Sounds like you have a short somewhere.
I would remove the switch and see if it comes on - if it does then do the same with the relay.
If it does not come on with the switch out then the issue is between the switch and the relay.
Similar idea with the relay if the relay causes it to go off the problem is between the relay and the heater element.
