I am new to this site and hope someone can shed some light on my issues.. I have a 2005 cayenne s. ... the check engine light came on with code p0204. The car was running real rough. The car lacks power and is very rough. I replaced all the plugs and coils except the one under the arm. Could not get the arm to swivel (any advive on that?) Could it be just that plug and coil or is there something else? Any help will be greatly appriciated
:welcome:
P0204 Cayenne V8 – injection valve on cylinder 4 – open circuit
Possible cause of fault
- Open circuit in the injection valve's control line
- Open circuit in voltage supply between injection valve and fuse
- Fuse F7 in fuse carrier in radiator tank E-box faulty
- Injection valve on cylinder 4 faulty
- DME control module faulty
Obviously check the fuse (F7) first.
  • 10 years later...
