Had the coolant pipes replaces w aluminum early on as most have. Unfortunately, the heater tees
were never replaced and one broke while out in the desert. not good.
Does anyone know whether the coolant pipe litigation covers these tees as well?
it does not. Only the pipes themselves or damage and maintanence related to replace the pipes.
You could try and see if you can say the tee's were damaged due to the replacement of the pipes, but other than that, they are not included.
