Has anyone ever tried MotorSilk additive in a 996TT? I have used it in my 65 427 Cobra with great results as well as two other cars. This stuff actually forms a molecular bond with metal to make it slipperier, thus less engine wear. It is a Boron based formula, not the usual snake oil, but the Porsche engine is a different animal than the 427.
If you are using a quality full synthetic oil, you don't need any additives.
Porsche uses Nickel, Silicon, Aluminum alloy and was probably machined to tighter tolerances. Check the VW Beetle blogs and forums. If it works for them then there is a good chance it will work.
2004 996TT X50 Engine -- US MSRP $74,703.27 (without installation charges).
I don't know about you but I'd be very careful what I put in that engine. :unsure:
I dont run motor silk but have been using AP Nano Tungsten Disulphide additive for 2 years with no problem. I have a 997 which is known to have cylinder scoring issues and even d chunk failures due to bad oiling and overheat conditions on two of the cylinders towards the front of the car. Im about to turn 90k miles and I have zero smoke on start up and she runs like a top. If its a real friction reducing additive and not snake oil, then I dont see the harm, unless it clogs the filter. The additive
I use is a nano particle and is smaller than the filter filters so it runs right through it.
  • 2 months later...
I literally just bought a 2004 996 Turbo yesterday with 50k miles. I was curious what type of additives are recommended to combine with fuel/oil/etc. I just went from a 2009 BMW M3 and a 2009 Audi S5 and without question the 04 996 Turbo is so much more fun to drive.
I'll repeat what I said above, if you are running a quality full synthetic oil, it needs no additives. Once a year, just before you do an oil change, run a bottle of Techron through the fuel system. Outside of that, no other additives are needed.
