Hi All
I have searched the Tech docs and the TSB's looking for WKD 493 710
Can anyone point me in the right direction
TSB's are listed under the "DIY Tools" tab at the top of the page, but I do not belewive what you are looking for is a TSB, but rather a workshop manual supplement:
Anti-lock Braking System 45
IMPORTANT NOTES ON TROUBLESHOOTING AND ON THE ABS TEST PROGRAM
A test program with ABS tester must be carried out after certain repairs to
the *** (see Function testing, page 45 - 06). ABS Test Plan, Sheet No.
WKD 493 710 is required for this test and for troubleshooting.
Hi Thanks for the reply
any idea where I can get that from
got an issue with the ABS on my 968
no fault lights but no ABS
thanks
thanks
You are going to have to search on flea bay and the like, that stuff is no longer in print.
I will ask my friendly local OPC see if they can find it in PIWIS
tried the bay of flea and just about everywhere else
Do as search here for a contributor that goes by the name of "Porschelibrarian", he often has access to this kind of thing.
