What is the part number for a PCM 3 for 2011 Cayman with Bose, no CD changer?
If I am able to source a PCM 3, what other parts are needed to retrofit? My 2011 Cayman came standard from the factory with Bluetooth and the Universal Audio Interface.
Thank you,
Peter
I think you'll also need to get it coded for the car, along with other modules which need to be able to recognise the PCM. I don't know a lot about PCM3, but to add certain features you need to get security (or licence) codes from Porsche. I would check that out before you take the plunge. You might be better to go with an aftermarket unit.
Is this for a US/Canada car or RoW?
You do realize the prices are going to be over $5500 just for the parts - before installation?
Loren - US Car. I knew it was pricey, but this is exorbitant.
Edited by Patriot
