V1 Remote Display in storage pocket
Options and opinions about installing the V1 itself have been discussed elsewhere so all I will say there is that I opted to use a fuse tap and ran it from the right side fuse box (I used the right headlight fuse (17 IIRC)). The main problem I had with installing the display was where to put it as it seems like every square inch of the dash is covered in buttons or something you need to see. After poking around and looking I found that the "non-smokers pocket" in front of the gear selector appe
