Main problem:
  • The idle is pending when pressing the clutch / going into neutral when having the aircondition on. Doesn't matter if standing still or moving. Has happened to me while not having the AC turned on, but only 50-100 RPM tops, towards the 700 RPM drop with the AC turned on.
  • Note that this ONLY happens when the engine is warm. (I can have the AC on with no problem until the engine hits 80°C.
List of things I've done:
  • I've claned the throttle body.
  • I cleaned the air flow sensor.
  • I cleaned the idle sensor located on the throttlebody.
  • I tryed replacing the idle sensor located on the throttlebody. (Borrowed from my mates 986)
  • I tryed replacing the air flow sensor (Borrowed from my mates 986)
List of solutions I've concidered:
  • The AC compressor. - Contacted a porsche dealer, and an expert told me they never, or atleast barly ever replace the AC compressors on porsches, since it's almost always other fualts.
  • Battery not taking enought chargeing?
  • Gererator or compressor wheel running slow?
Video of the problem : (I'm really sorry for how the video was recorded. But it was the best way to hold the phone while driving without dropping it.)
With kind regards, Jonathan from Sweden.
Edited by HolmaN
