I have an oil change coming up and I plan on changing the air filter in my 1999 C2 at that time. Is it worth pulling the MAF and cleaning it while I'm there? Last time I checked it with the Durametric, the readings were in spec, so I don't think it's that dirty. I am just unsure whether periodically cleaning it will extend the MAF's life by reducing the likelihood of build up, or if it will reduce its life due to applying chemical cleaners.
Thank you!
Don't touch it unless you have small hiccups or stalls during acceleration. If so, you can try to clean it with electronics cleaner, or change it if not better. It's the easiest part one can change.
If you have an "oiled" filter then it might make sense to clean it every year or two.
But only use MAF cleaner and allow it to air dry before operating.
