Hello,
Just purchased an 04 Cayenne S. It's in nice shape with a TON of service history. One thing that is not working is the drivers heated seat. The passenger seat is working without a problem. The fuse is good. I have read that it could be the relay/heated seat module. Since the passenger seat works, I was going to swap that over to see if it fixes the problem. I have two questions.
1. Is there a relay and a module, or is it one in the same?
2. Where are they located? I know they are under the seat, but where? And does the seat need to come up to access them?
Any help would be great.
Thanks.
There is one relay under the dash which controls all the seats.
There is one module under each front seats, I think it is yellow.
You will need to remove the bolts on the seats to access the module.
I might have some documentation if you need it.
