I have an '04 CTT with the external spare tire carrier. I am getting the warning that the carrier is open. This warning is constant and overrides everything else on the dashboard display, pretty much making the car undriveable.
In researching the issue it seems that I can "turn off" the warning by unplugging a connector going to the lower hinge, simply by "removing some trim".
My problem is that I'm not sure what trim, and I'm also not sure what "lower hinge" means.
Does anybody know if I need to find the connector at the hinge, near the tailights or is it the receiver where the carrier latches into?
Also, does anybody know exactly what "trim" I need to remove? It looks like my manual has the wrong diagrams for removing rear apron.
Thanks.
