I did it. Thank you for the documents. I used emergency lever, opened the the second glass part by hand . 6 screws and the roof part is in your hands. Get access to the wind deflector which is the very first part of the pano roof. There was a mechanical small plastic part which wasnt fitted correctly. Easy job to bring it back to its original position. Deflector moving up and down. Install the glass part again. Done. Relearning process according documents.
Here i am again. The car stay for some days and now nothing is working. Dead. I had to use my other cayenne to start the turbo via cable. Car started without problem. After i used the multimeter i bought to messure the voltage. Looks like the alternator us ok. The multimeter is showing same numbers on the turbo like in the s. So as i understand it cant be the alternator.
Tomorrow u will change the batterie. I will see what will happen after.
What i am wondering about it the following subject.
The car is locked. Lights switch off. But the dash is fully iluminated.
What the ...... Is this?
