Cayenne door trim strips - trim pieces that doors close onto
The trim strips are located on on lower part of each door entry, and the door closes onto the trim pieces themselves. Sometimes, when exiting the car, your foot can catch the edge of a trim strip, causing a clip underneath to break, loosening the strip. After a few clips are damages, the strip is very loose and you may need to replace all clips to repair this. Attached pics show which trim strips these are (total 4 on the car - 1 per door). Tools needed: - Cleaner to clean strip
Just did this with my 2004 Turbo. Just want to say that you don't need to hammer in the center locking posts. They'll push in with moderate pressure. Just use anything that's bigger than they are. They're about 1/8 inch diameter. I used the tip of a pair of small pliers. Works fine!
