Just wondering if anyone has seen that code before? Heck I've seen 'em all but not yet that one;) Doesn't give me any info either on my scanner.
The 7.8 dme manual says p1674 is an engine compartment purge fan problem, either an open circult or a short. Check the relay and wiring harness.
P1674 Tachometer Control Circuit
Not sure what it does. Does your tach work or have you made any modifications?
Beeezare... Hmm actually yep I had a short there and had to go through the wiring harness:( Sucked major butt.... OK so that one's not too serious then:)
Thanks as ever!
PS I hope you can make May 7th Loren...
