Truck as a fresh alignment. When I brake, the car pulls to the right - and down a bit. Any ideas on what this might be?
Check your tire pressures first.
Could also be a sticking caliper. If this is the case, aside from uneven pad wear, the sticking brake can produce a good bit of heat. Take a short ride and shoot each front rotor with an infrared thermometer. A noticeable difference in temperature would confirm this diagnosis. There are also tools that measure brake pad pressure, but that's usually not needed.
Thanks for the feedback - it seems to be getting less noticable with time driving, so I'm thinking it could be corrosion on the rotor after sitting for a while. I've brought it to a pro to figure it out. I'll let you know what I find out.
  • 2 months later...
I checked rim temp - neither side seems to be getting hot, Checked the air pressure on bot front tires and its 38 as specked. The car has a fresh alignment - 1000 miles ago. How do I check for a bad tire? They are Nito tires - kind of an aggressive tread - could that be the issue?
If it is being caused by a braking fault a vehicle pulls to the right if the right hand brakes are stronger than the left hand brakes. It could be a stuck caliper on the left side or a stuck piston.
Can anyone recommend a good service company to rebuild the calipers if that's the way I should go? Any opinions on rebuild vs new? I'd rather not waste my time with a rebuild if its not going to perform well.
Check your lower control arm bushings! My '04 CTT did this same thing even after brand new brakes. Replaced both lower arms and the problem disappeared. So did the 70-80mph steering shake and "clunk" when braking.
Cluck has the idea, I have a 2004 CTT and I got a bad clunk and I replaced both bushings and it's gone.
