Hello to everybody
As mentioned some days ago i went to buy a Cayenne Turbo S from 2005
Everything ok so far. I am still in the period to get used to it. Its almost the same than my Cayenne S.
Just one problem i have and would like to ask your advice:
My panoramic roof had worked proper but now suddenly the draft deflector doesnt move at all. It isnt closed completely, stays some mm higher than it should be when its closed. I try the learning process and everything what is written in the manual.
Nothing helps to make the deflector even moving. It is stuck in this position. If someone has a idea what i could try, will be glad. Thank you
Check out the Panoramic Sunroof thread on Rennlist and you might find some help there. It has a recent post so it is on the first page still.
