Yes the Tiptronic had it's own control module (computer) that talks to the car's other control modules.
The standard transmissions (both 5 speed and 6 speed) are all mechanical and have no control module.
Are you considering changing your Tiptronic out for a manual transmission?
If so, that could be quite a bit of work.
No. I'm considering some upgrades on the engine and I can obtain the programed ECU for the upgrades. So I was wondering if it would be a simple swap as far as ECU's go. I realize the "programed" part was for another engine but I think it would be very close. Engines are the same displacement etc.
