Hi guys, I'm new here. i hope to contribute to the site in the future, but for now I have a problem.
Here's what happened:
I bought a 1998 996 C2 3.4. Last week the ignition switch failed so I sourced a new switch (Audi/VW part)
I couldn't get the old switch off the back of the ignition barrel, so I just unplugged it, and plugged the new switch in and left it dangling. The car then started and ran fine by turning the switch with a screwdriver.
The car was then left for a few days, during which the battery went flat. After charging the battery the following problem has occured:
1. The drivers door key lock just spins freely, without locking or unlocking the car. No resistance whatsoever! Remote central locking doesn't work either.
2. The car will not turn over or fire when using the screwdriver to turn the new ignition switch. The keys are still in the barrel, I figured in case they need to cancel the immobiliser.
Any help would be MOST gratefully recieved. I can offer nothing but my thanks, and possibly some naked pictures of my girlfriend if required! :D
Ben
Ben,
I performed this replacement about year and half ago and followed the Ignition Lock DIY here in Renntech and had no problems.
Hope this helps.
Best, Rob
Thanks for that!
Oddly enough it worked fine after the switch was correctly installed.
I fail to see how that is possible but I'm not complaining!
For reference I'd highly recommend the Picquik Teeny Turner as the tool of choice for the job. Those retaining screws for the switch are a sod!
