I was doing some maintenance work and hooked up my Durametric and tested all modules. I got a fault in the PDK module I had not had or seen before.
It was Durametric Fault Code: 50200, which the folks at Durametric said was described as U0418: CAN fault, brake.
Anyone have more information or details about this? As an aside, the PDK seems to be just fine in all phases of operation, so I am wondering if this is a non-event.
Thanks.
  On 2/14/2014 at 2:11 AM, Loren said:
U0418 - Stop light switch
Possible fault causes:
- Open circuit in signal wire from stop test switch
- Stop light switch faulty
Thanks Loren. This helps to narrow it down a bit more.
  • 6 months later...
