My Kremer 930, built September 1982 refuses to start. The fuel pumps can no longer be heard at initial key start (ie pumps not working). Cracking the airflow meter open turns pump on. Can anyone suggest the next items to check why the pumps are not working? Regards, Peter
Thanks Loren, the pumps turn on and run OK when the wiring plug on the airflow meter is disconnected, so the issue appears to be somewhere in the electrical system.
