So who makes the best reliable lithium Ion Battery that weights no more than circa 10 lbs at a reasonable price ?
You have just used two completely incompatible concepts in one question: "best reliable lithium ion battery" and "reasonable price"..............................
The factory Lithium battery is running about $1800 (US), aftermarket units are about $1400.
These are the minimum specs you need...
12.8V
18AH
480 Amp
You can make your own out of LiFe PO4 batteries, a little web research can teach you how. Cheaper then buying them turn-key but still not cheap.
