Sending a feeler on the auxiliary water pump. This is the pump that is located behind the left (driver's) side inner fender cover. It pumps water for the heater, basically. I've noticed it getting louder and louder so I'm guessing it is going out. I haven't heard or come up with much on a search. There is a TSB to add foam tape to quiet it down and I did a home-grown version to see if that would help but it didn't. But it really didn't make this much noise before. I was curious if anyone had replaced one before so I can guess how much coolant will need to be removed. Once you get to the pump it's pretty straight forward. Part number appears to be 95557215002.
Edited by the head
