Cayenne Wiper Blade Refill
So one of the things i hate most about our wiper blades are they are expensive and with the winters, they need to be replaced every year. So i figured let's take them apart, figure out how they hold the "insert" and replace just that. Similar designs are now used in Honda and Toyota, since the rubber insert is significantly cheaper and easier to replace than the whole blade. You will need: Flat blade screwdriver Sharp knife or scissors New Refills (can be found at several locations) -8th
