Hello,
Can I swap out my S Cluster to the CTT cluster? Is this even possible? I found a CTT cluster that is brand new and wanted to swap it out. But before I buy it I need to know if its even possible. Thanks!
So what does that mean? I've done a bunch of searches and I've come up with nothing. Are the connections the same? If so then it should be a plug and play. Do you have a link that will guide me to the previous posts? All your help is greatly appreciated versus your previous comment. Thanks in advance.
