...This should be easier than it looks. I have removed the pressure hose from the turbo (cylinders 5-8) and noticed that the aluminum casting between the pressure hose and the turbo has some play so while I was doing the job I thought I would replace the rubber O ring at this joint.
Unfortunately, the casting has a short rubber hose attached going to what looks like a vacuum control pod and there is not enough movement in the hose to pull off the casting to get to the rubber O ring. I loosened the clamp at the vacuum switch but the hose but it wont pull off and I don't want to break the plastic fitting. Is the only answer to cut the hose and then replace it?
All advice gratefully received
Steve
If you search in Rennlist.com. "DIY 05 CTT Pressure-Pipe O-ring removal" here you will find the info. Sorry couldn't figure out the link.
Many thanks - I found it. The rubber hose is still not prepared to budge so I will cut it off and replace it as the easy solution. Parts arrive tomorrow and hopefully I will be driving her again this weekend
Steve
