Hi All -
Just bought a 2004 Cayenne s. Most of the usual suspects have been repaired already - tubes, fuel and water pumps, serpentine belt and battery and some of the coils.
Should I have the drive shaft replaced at this point or wait for it to fail - is it 100% it will fail?
how many miles do you have on the car? I'd wait....they don't just explode all of a sudden, you will start feeling and hearing the vibrations under acceleration first, so just replace it then.
...replace all of the coils (not just a few)and do the plugs at the same time. I stayed with the OEM Beru plugs from Sunset Porsche as the last set did 100K as far as I can tell. Get a Porsche dealer to give you history on the car and you may find (as I did) that the Cardan shaft and plug packs have already been changed
Steve
