This is probably a silly item, but I am curious.
I had reason to remove the rear license plate the other day. Behind the plate is a inch and a half diameter hole..... which, of course, is the where a ring-eye type bolt would be screwed in if the car needs to pulled up on a flat bed.
This hole was not covered. However, the owners manual mentions that a plug needs to be gently removed before attaching the towing ring.
I bought my '03 Boxster new. Did US models come equipped with such a plug?
