After a rear window regulator replacement my top wouldn't go up. the top had been in its service position, and had leaked down the rear lip was still up. I went to put the top down, to lower the rear lip, then hit the raise button nothing happened, I need to get the top up so I can raise the regulator to install the window. If I put the hardtop on will it allow the rear windows to go up? So I can put the interior back together. Then if need be off to the dealers.
You should be able to depress the switch in the roof hook receiver on the lighting console located above the front window. This should allow you
to operate the rear window regulator assuming it is clear of obstacles.
Thanks, The fuses were ok, by putting my finger into the top latch I was able to move the rear windows up, Installed the glass, put the top up but the top lid didn't go down. I used the Allen key to move the lid down, but the top light is on.
Tried putting the top down but the lid didn't move I opened the lid with the Allen key top went down, put it back up allen key to move the lid back down, top light on.
Will I have to go to the dealer to have the top reset, or is there another problem.
