I have been trying to replace the rear window regulator. My question How do I back off the bottom nut on the regulator? I had to grind down a 13mm wrench so it would fit in to the slot, and mounted it to a wood stick so I could get on the nut. I moved it a little but nut enough to allow me to turn the ground down open end and move it again. Is there a tool made to allow me to the loosen up the nut. Or any other ideas?
