HI guys
looking for some help here to avoid a massive bill. I had a flat battery over Xmas and after jump starting the car I had the weirdest problem. Basically anything with a needle stopped working on my cluster. Everything else works including the electronic speedo.
Car went to specialist who has full porsche Bosch diagnostics. error code was related to one of the PSU's in the dash showing only 2V
they followed the fault process and confirmed the two 12V feeds to the dash are present at the plug
at one point very briefly they came back on but apparently the fault wouldn't clear and after switching off ignition an on they went off again and have not come to life since!!!
they downloaded and re- loaded the dash S/W still no joy.
tried fuses even tried new battery still no Joy
conclusion = buy new dash £1700 plus VAT!!!!!!!! plus 4 hrs labour messing about
I wasn't keen on this so option 2 send cluster off to a specialist repairer - no joy apparently they cannot help
option 3
2nd hand cluster and this is where I need the help hopefully form someone who has tried to do this.
I have found a second hand unit with 27K miles from a 2006 C4S manual - the number is 997.641.117 20 D07
mine is a 2005 C2S Manual 997.641.117.33 D07 with 34K miles
the 4S has same options inc. chrono pack.
I have found somone who can correct the mileage for £150
I tried phoning porsche who were helpful but said the part number needs to be identical to be compatible - they couldn't help me
I cannot find another 2nd hand part with an identical number in any breaker in the UK
my specialist has no experience of trying this other than with brand new dash.
Hoping someone can tell me if I can make the C4S part work - if I got it and plugged it in
a) can i cause any damage!
b) even if some items weren't functioning should the gauges work again? - thus proving the diagnosis is correct before getting a second mortgage and at least being able to use my car again
Hoping someone can help!
cheers
Ian
Hi Firmsi,
My cluster was replaced under warranty as it got electrocuted by a wayward PCM. The cluster with Speed Yellow dials was $4000.
Anyway, your problem is the Sport Chrono part. The clusters are not the same and the C4S part will not work so, don't waste your money. You can not just plug one in either as I believe it has to be programmed in the car with a PWIS unit. I am not sure if a Durametric will do it. This means it has to be done by a Porsche dealer. I think you are stuck here. Doing anything but getting a new unit installed by a Porsche dealer is risky and in all probability you will just be throwing good money after bad. Also, if done by a Porsche dealer the part will have a warranty which is very useful with these cars. I feel your pain.
