Hi guys
Just got my 2008 TT Cab back from the OPC after minor 6 year service (brake fluid, fuel filter, 4WD Oil change, poly rib belt change as extras). Car has done 23k miles.
Today the car has had a clunking as I set off in 1st when clutch let out, can feel a punch in the back sensation (and not the usual nice n scary one). The clunking continues if stay in 1st at low speed. seems more evident when the engine is warm and I was crawling in traffic.
Wondered if anyone had experienced similar?
I'll be back on the phone to the OPC tomorrow for certain!
Cheers, Mike
Hi guys
Cheers, Mike
It sounds like you have a bad motor or transmission mount. Not uncommon.
Diagnosed as a dodgy batch of oil used for the 4WD oil change. One for everyone to look out for should they have the same symptoms.
