I recently installed an AIM Solo DL data logger in my 2007 C4S Cabriolet. The battery has gone dead several times while at the track and I would like to wire it so the car's battery will charge. As the Aim Solo is wired into the Can Bus directly, I would like to find out if there is a 12vdc ignition switched wire that goes into the ECU and which wire it is.
