Had to change out the Front Left wheel bearing in my cayenne today. Accidentally pulled the shaft out of the diff when pulling on the spindle and can't get it back in now. Is there any advice for me? Job was going well up to this point.
Thanks in advance.
It finally went back in with some axial effort. Thank goodness. Went thru an incident with a ford expedition once, where the rear axle came out and the spider gear moved out of postion. That sucked, but at least I could access the diff. Can't express how happy I was to see it slide back in. Had horrible visions of having to take the front diff out or remove the strut so I could remove the shaft to see what was going on in there.
Wheel bearing went in really well too! Nice and quiet again!
All is well that ends well!
