Got a 88 S4 auto trans and when I go from park to select any gear it tends to engage a little late and jerks. Once into gear it runs and drives smooth, no problems.
Could in be that the linkage/cable needs some adjustments?
Any ideas what could be the issue?
Check the vacuum line that goes from the 5way(?) splitter by the brake booster to the modulator on the transmission. If the line will not hold vacuum, the shifts will not be smooth, but more abrupt and rough.
  • 4 weeks later...
Got under the shark and noticed that my trans pan was leaking ATF. Hand tightened and add more fluid. Now it engages nice and smooth.
