Have a 2008 TT with 19" standard wheels with regular brakes(iron). Can someone tell me what the diameter, in mm , the front and rear rotors are?
Rears are 350 mm.
The fronts should also be 350 mm unless the GT2's 380 mm rotors were installed.
Plus there are different rotors for center-lock wheels...
If you want PM me your VIN and I will look up what was factory installed.
New thicknesses are:
Front: 34 mm
Rear: 28 mm
Wear limits are:
Front: 32 mm
Rear: 26 mm
Peak-to-valley surface roughness of brake disc after machining (max.): 0.006 mm
Thickness tolerance of brake discs (max.): 0.02 mm
Lateral runout of brake disc: 0.03 mm
Lateral runout of brake disc when installed (max.): 0.06 mm
