Purchased an 02 C2 cab a couple of weeks ago. Great car!
When I was exploring buttons on dash I found a display that showed about 6 pictures of gauges including a speedo that said Max speed 130 MPH.
I cannot figure out how to get back to that display.
Anybody know how to find this display??
thanks
rbc
No photos, no third party nav. system. Was just poking around and it popped up. Assumed I could get to it again but..........
On my 01, there is a setting to alert the driver when you reach a preset max speed. I have mine set for 70; when i reach 70 mph, I get an alarm beep. Mine is controlled by the shorter lever right below the turn signal lever.
Can you post pic of the display?
Al
Not in owners manual, can't post picture as I cannot figure out how to get back to it. It is not speed alarm.
I think you might find it by selecting LIMIT on the OBC with the lower left hand stalk. From memory, you push the lever forward, and then move it up/down to scroll the options. Select LIMIT by pushing it forward again.
DISPLAY IS ON SCREEN UNDER TACH
ACTIVATED BY LOWER LEFT LEVER ON STEERING COLUMN
SEVERAL CONTROLS FOR SCREEN BUT INTUITIVE SO JUST PLAY WITH IT
I KNOW YOU FRUSTRATION HAVE OWNERS MANUAL BUT NO INFO FOR PCM
2002 C 4 CAB
