I have a 99 boxster. While trying to install the update brake booster bellows kit I tried to clean out the drain hole grommet under the brake mechanism to the right of the battery as you are standing in front of the car (USA spec). Needless to say I pushed it in and couldn't get it back through the hole. So my question is if I don't replace the grommet where does the water drain too? Should I replace the grommet? If so how can I get to it to re-install it? Am I better off just buying a grommet and popping it in? I would like to resolve this as painlessly as possible since I am installing the update to the brake booster bellows I don't want to get a flood elsewhere. Can I just buy another grommet and hose and install it? If so anyone know part numbers?
The bulkhead grommets in these cars are directional, meaning they insert from only one side. Why not recover the one you pushed out and reuse it, or if it cannot be reused, definitely get a new one. In either case, a quick spray with silicone will make pushing back in place a lot easier.
