Hi all, I have a question I'm hoping some of you can answer. I just had a set of H&R springs put on. The Indy shop who is doing the work (a good shop I trust) is working on the alignment now. There is a negative camber due to the springs, however the adjustment is maxed out trying to bring it in and it's still at around 2. The rear right side is fine, it's only the back left that has no more room to come in. Any ideas what's going on? The drop from the springs was very minimal, maybe a half inch, so it seems weird that it would be pushing the camber out so far. I also added a 7mm front/15mm rear spacers, but everything else is stock. This might exacerbate it a little, but shouldn't prevent the wheels from coming into alignment. Any thoughts?
