Fuel Door Actuator Removal DIY
So I thought I had a fuel door actuator issue and I went ahead and replaced it. I did a DIY to help anyone in the future. I will keep it short and sweet with many pics. Actuator itself. Part number Remove the rear passenger panel cover first. Detach the trim, (clips to pop) Remove floor section Remove screws Pop out harness Remove dome light Start at end of center interior section Remove center Section Remove corner section Remove Side Piller Section Remove
