what durametric i have to buy to calibrate conv top ?. i chage 2 cylinders and the potentiometer on the left side cylinder, it work for 3 wheeks ,start to fail and now is on the retract position and noting works. they said it need to be calibrated . but it was working good for 3 weeks......i have code 5 and the top light is always on. .i have the lauch but not calibrate the roof,
thanks in advance
Edited by 996SFL
You would need the Durametric Pro version.
Or... find someone near you that has one (or a PST2 or PIWIS tester).
You did not put a location in your profile so you would need to tell us where you are...
  • 4 weeks later...
I'm at a loss here. I'm stuck in the closed lid position.
I tried the emergency close mode listed in the owners manual,
Turned the crew at least 90+ times counter clockwise with no results. Did the cables snap? if they did I should be able to pull the clamshell open by hand.
There must me a latch that's stuck or broken in the close position.
while cranking the screw it seemed to lose tension after turn 10, now it seems to be just spinning.
Electric motor runs for a ±10 seconds then times out.
any tips would be great I haven't seen this problem posted.
Can you tell me where the (3) latches are located?
BTW:looking through the open flaps with a flashlight the rams seem dry, not indicating a leak.
