I was getting an error 4200 which tells me there is an issue with the right front speed sensor. so I got a new speed sensor and am trying to remove the old one. Does anyone have any advice on how to get the old one out with as little drama as possible? PB blaster? Slide hammer and a couple of screws? I have a 99.
Usually you just take the bolt out then tap and twist until it pops out.
PB Blaster would likely work too - but clean it all up before installing the new one.
