Once the weather gets cold outside, my multifunction display shows the fault "Warning Chassis System" almost on a daily basis. The fault always occurs when I am turning left and usually occurs within the first 10 minutes of driving. The fault stays on until I turn the car off, they it clears. The local Porsche dealer did not find any stored faults and the one local independent I stopped by with the fault showing could not find any faults using his code reader.
Does anyone have any suggestions? If I bring it to the dealer with the fault showing will they be able to determine the cause or do some faults that clear as soon as the condition clears.
If you have access to Durametric software (or a PIWIS tester) it will narrow down the location of the fault(s).
There are a dozen or so possible faults just in one controller - and the Cayenne has about 20 controllers.
I was not able to pull a fault with my durametric, but was finally able to get to my local indy mechanical with the fault on. He found PDCC/ORS code 15627 Rear Axle Chamber 2 low pressure.
Any suggestions on what is causing the low pressure?
Did you check the level in the PDCC reservoir?
If that is okay - then you will likely need a PIWIS to further diagnose which sensor and what may be bad (pump, valve, etc.).
