Found suspicious oil leak when I was changing the rear wheels today. Seeking help from more experienced members here to diagnose the problem! Please see attached pics.
Car is a MY2000 Boxster S manual, with approx 60k miles. Serviced regularly at 5000km interval.
Oil is not dripping, none found on the garage floor. Car runs very healthy as far as I can tell!
Apperciate any help.
\url=http://s235.photobucket.com/user/sagacier/media/20131125_040701.jpg.html]20131125_040701.jpg[/url]
Edited by panameras
I would recommend to clean the engine properly in first place and check for leaks after a while, in that way it is much easier to detect a leak, saves time and is more efficient.
Thanks, would definitely get on with cleaning it first. So no obvious signs of what it might be at first glance?
From this picture alone, you appear to have leaking spark plug tubes, but I would agree with RFM, clean the engine bay first so you can see what is actually going on:
I agree with spark plug tube o-ring diagnosis. Had same issue on my 2001 986S at 35K miles, but leaks had not progressed as far as yours. It was simple and inexpensive to replace both o-rings. I decided to replace the tubes while I was in there for a few bucks more. Tubes are plastic and degrade with exposure to temperature over time. Didn't want to risk future cracks by re-using old tubes.
I had similar leaks underneath the car and re-torqued oil sump pan bolts and leaked stopped. 7.5 ft./lbs. Don't overtighten as they will snap off. Clean everything up and re-check for leaks. If that doesn't work you may need a new gasket and sealant.
Edited by kbrandsma
  • 4 weeks later...
spark plug tube and the o-ring degrades with heat and time. Mine shrinked and leaked. They also got brittle when removing they shattered. Fairly inexpensive from the dealer
It's a good idea to buy a set of o rings and a couple of tubes and every time you change your plugs you can replace those that are leaking. Fairly inexpensive, I change my plugs every 30K and have changed 1 tube and 3 sets of o rings over the last 3 spark plug changes. MY98 is currently at 180K.
Also a good idea to have a boat plug on hand for popping out the tube. I bought mine from a local boat/marine store for less than $5. It literally pops out like your finger from a coke bottle.
