I know rotor size is different, both calipers 4 piston (one black versus red) but any other difference? As an aside, are wheel carriers the same? Looking at putting 981S rotor/pads onto 981.
The 981 S front rotors are 13.0 X 1.1 inch, rears are 11.77 X 0.80 inch, the non S fronts are 12.4 X 0.80 and the rears are the same 11.77 X 0.80 inch. As Loren noted, the carriers are the same.
So do you think I can simply put the 981S front rotor on the 981 without problem (except pad change)?
Not without checking to see that the calipers are also the same, which I would be will to wager is not the case.
  • 2 years later...
I have looked this up on the PET on a dealer parts site. The calipers are indeed different part numbers, even though they look identical.
Sent from my iPad using Tapatalk
