I noticed that the rubber bushing on the front suspension sub-frame are torn.
my question is how hard it is to replace them and what are the torque specs?
it is # 16 in the picture.
thanks
post-69261-0-10460200-1385006684_thumb.g
95534113301 and bolts 2x N90998701 and 2x N91009302 not sure about the specs though. Bushings $38.59 each from Sonnen and the bolts just under $3 each.
thanks
I sent you a PM with the torque info as it is too much to post here.
thanks guys, I inspected the bushings today while doing oil change. I think I will hold on to them a little longer.
there are instructions on VW Touareg's , they are the same I think. it involves special hydrolic press to take the old ones out. not sure if it is DIY.
Yea, unless you have a Hydraulic press, one of the better Harbor Freight ones should do, then you would need to take the whole cradle to a machine shop and have them press out the old and press in the new.
P.S. If you take it to a machine shop tell them it for a VW, they'll probably charge you less than if you tell them it's for a Porsche.
Edited by hahnmgh63
I'm new to the CTT (and the forums, first post). Picked up an '05 with 81k on the clock last week and took it to the local indy to have them look over it for piece of mind, as I generally suffer from terrible caranoia.
Car's good, but they noticed that the front left bushing (so I think 16 in the diagram above) is on its way out. They said to keep an eye on it and see if it degrades, but I'd like to just get it over with for piece of mind. My questions:
1) Am I correct in wanting to get this sorted ASAP, looking at the pics below?
2) Do you really have to disconnect the engine and gearbox on the CTT in order to replace these bushings, or is it sufficient to follow the instructions found here? http://vwts.ru/suspension/touareg/tou_40.pdf They mentioned it's something to do with the engine being too heavy to be supported by a jack, but this thread doesn't seem to suggest that it's that big a job.
Here are some pics of the left front one (so the one that's going), and then of the right one, where the bolts seem to sit slightly lower.
Many thanks for any wisdom, it's very much appreciated. Here are the pics:
The one that needs changing:
Znn7lAo.jpg?1
vaa1rus.jpg?1
The other one:
N9lDOHX.jpg?1
9yP5L2N.jpg?2
