Just got a Durametric. After clearing all faults, a few remained that I am not familiar with. What does: 8035 - Interior sensor fan indicate? A/C seems to work normally. Non-issue?
Jason
8035 Diagnosis information rear - Reversing light
Possible fault causes
- Open circuit/contact resistance in wiring, sockets, plugs and terminals
- Short circuit to ground in wiring
- Reverse gear switch faulty
- Tiptronic control unit faulty
- Short circuit to ground in point SP039_SPRFL_2 (driver's seat) of the ParkAssist control unit
Thanks for the quick reply. Well, it's a manual so tiptronic is out. I also do not have park assist, so, that's out. I guess it's down to the first three. I cleared the faults and this one did not come back. So, I guess I'll keep my fingers crossed on this.
Jason
  • 11 years later...
I’m experiencing something similar. The AC/Heater works, but the lcd screen flashes three times when I turn on the car and doesn’t read or regulate the temperature correctly. My icarsoft shows interior sensor fan code 8035. Did you find a solution?
Reread what Loren posted above:
And please do not double post your problem, it is against forum rules................
