Finally got myself a Durametic tool. Hooked it up the other night and found several faults, most of which I knew about. However, there were a few that I wasn't aware of. Specifically:
8037 - Number plate light.
Sure enough, I checked and the plate light is out. Does anyone know if this fault simply indicates a blown bulb or is there a bigger problem?
Jason
PS - I'll post separately about the other faults.
8037 Diagnosis information rear - License plate light
Possible fault causes
- Open circuit/contact resistance in wiring, sockets, plugs and terminals
- Failure of one of two bulbs (2 x 5 watt)
- Short circuit to ground in wiring
Thanks for the quick reply. I guess I will start with the bulbs and go from there.
Jason
