Sorry if I'm wrong on this one but I *think* there's an easier way...
I read somewhere that you'd have to remove the entire unit/console from the roofliner and remove the circuitboard....
HOWEVER: if you pry of the lightcover itself you can then pry of the entire button-bezel with the centre button still attached.
This is held in with plastic tabs and comes out very easily and repeatedly without breaking the tabs....
So no tools needed at all, simply take off both the lightcover (optional really but gives you a little easier acces) and the bezel and you can fix the light!
Hope this helps!
